Limp mode after new planetary gears
Aug 15, 2022
14
I opened the valve body. Everything looked clean including the filter screen from what I can see. Should I use the boring tool or scotch Brite or another way to fix that stuck valve. I was also going to replace the pcm. Back in 2003 MikeL said he never saw a bad pcm. Someone else said they are notorious for going bad. Maybe they started going bad after 03?
08lmm72mm
544
169
Canada
In 2003 these trucks were fairly new so the probability of TCMs going bad wouldn't be common at all, hell they still didn't even know their injectors were junk at the time.
08lmm72mm
544
169
Canada
Even still 4-5 year old trucks isn't much time to show electrical gremlins compared to 20 years which is where we are at now with LB7s
juddski88
Freedom Diesel
Jul 1, 2008
4,659
130
Chesterfield, Mass.
Is the valve sticking?
juddski88
Freedom Diesel
Jul 1, 2008
4,659
130
Chesterfield, Mass.
It should move freely. If it doesn't, clean the bore and valve well with brakekleen and try again. If it still hangs up, then you can try taking a smaller spring, like an accumulator spring, put it deep at the end of the bore and then work the valve in and out quickly with some standard PS fluid. May take 100 strokes or so....then clean the bore and valve again with brakekleen, and retry normal operation with trans fluid. If that doesn't work, then a reamer is going to be the next step.
993
Do not take scotch brite or sand paper or steel wool or any other abrasive to the valve or the bore or you will be looking for a new valve body. Sonnax makes a tool to help fix the E-valve bore if you can't get it working properly.
Aug 15, 2022
14
Truck is good now! No codes. Rides good. Hopefully it is a permanent fix. I appreciate all the helpful advice given here. I read the valve could have been stuck because truck was shifted into gear with only 8 qts of fluid instead of 13. My mistake for trusting the fluid capacity advice of well known online diesel supplier where I bought the transynd 668. Does it need to be relearned? Only removed the c5 clutch pack and put the same ones back in with the new planetary gears. Didn't touch the others.
3,149
id just drive it easy until it is shifting smoothly through all the gears, then a little more aggressive until it's smooth through that driving style. do this until you can go full throttle without it hanging or banging into gears. start slow and work up the power
