Anyone play with making knives or hatchets??
finally got the knife blanks back from the heat treater. finished grinding the kitchen knife and put a handle on it. made my first wooden scabbard. a little rough but will do. might resand & wax it a bit more and try and polish it up. now since I missed finishing it for his birthday and ended up making those knives in the above post, do I give this to him right away or hold onto it for a Christmas gift?
after this I get to work on that 2nd knife from post 55. that one will be easier as it won't require as much post heat treatment grinding to finish and I'm not going as thin with it. not sure yet if I'll go kidex or leather for the sheath. and do I keep this one or give it to my uncle as a skinning knife for his hunting trips?
5,101
703
Personal I like the finish you have on it. Especially if he likes the rustic look.
Another set for you to see. One is a push dagger the other, i don't know, maybe a fighter?
Cut from 5160 flat bar
Cut the bevels by hand with a file. Mostly draw filing. Turned out better than I thought it would
After a little touch up on the belt grinder. And ready for heat treatment
I'll either fill in the handle lightening holes with epoxy, wood or micarta. Not sure yet
shakenfake
Moron
Sep 15, 2022
417
202
Shlumpt, TX
My vote would def be epoxy though, that would look sweet. Throw some food coloring it in or something too maybe...
Only on the fighter though, push dagger I would leave alone.
3,931
830
Doug Marcaida... I think he's the best to watch test stuff. One of the other guys just likes beating the piss out of the blades
Yeah, they are all pretty bad for real world testing and use but Doug is probably the best out of the bunch. Ben Abbott has the most respect from me as a blade Smith. Actually being one and winning the competition twice and beating out on of the other judges in the process too. Other then that their testing process is suspect
Kydex maybe? That I have used before for a moldable plastic.
I use kydex sometimes. This was a random plastic tube I found and used. Worked great. Have no idea if it is as durable as kydex but seems to form just as well
Wanted to try my hand at actual forging. Got me a cheap Amazon two burner propane forge. Not a bad unit. Requires a lot of assembly.
Anyways. Decided to start with just the bevels. Leaving the more intricate handle forging for when I'm more skilled and aquire the tools needed.
Leaf spring steel. Possibly 5160 but can be a number of different alloys. Started out well. Put the bevels and curve in. Was making a large chopper as I feel it would be a little more forgiving with errant hammer blows.
Hammered out the basic shape
Ground in the bevels. Shaped the handle and hardened the blade
Then... During tempering. Well actually after removing it from it's 2nd cycle and cooling it off it split in two. It's weird because it didn't make any "tink" sound or any warnings. It just kinda fell off ?‍♂️
The grain structure was not too bad. Almost ideal. Just slightly more texture then optimal. But should have been serviceable. There is a brown section near the spine that gives the tell-tale sign of the issue. This must have been there since the initial quench and remained unnoticed
Welp, time to get some more propane and start again. Luckily I have a lot more leaf springs to play with
darkness
1,586
613
vegas
There is a very definitive line between the browning and clean forging. Is that do to more hammering of the bevel?
Unlikely. The "brown" crack extends a little past the straight spine section and into the bevels a little. It would also be much darker if it happened during the forging process. It would have to have gone through multiple heats for forging, normalizing, annealing and the austenitizing. It would probably be black by the time. From the light browning it more than likely cracked near the end of the heat cycles. Probably the quench where the chances are the highest
