Who are the Trainees? What are you training them to do?Trainees loaded and headed to Joplin Missouri. Going to go check on that little Cummins Marine project, and hopefully rebuild these puppies over the weekend.
Anyone interesting to see along the way?. Mark said I can't wake him up at 3 a.m. however. LOL![]()
Sent from a reclined position using Tapatalk
Clutch has arrived, same dang ones I had. Okay where's all my tranny guys, transtar no help.
Alto clutch 111704 is what we need.
That would be super.
Issue we ran into is everyone keeps cross/ref the Alto # over to over to a standard Borg 4T80E 3rd gear, which while correct, is a paper rather than fiber. I was told by someone yesterday that Raybestos make them in a fiber, but guy didn't call back.
Here is a pic of what we tried last time, and received today.. That part # should be a waffle like in second pic..
Sweet. We believe that part# is correct, but best ask they send ya pic. Last time he ordered any was 2006.I’ll let you know Monday. If that’s the correct PN there’s a 99% chance that’ll be easy to get as long as I specify it must be waffle cut as my main supplier is familiar with that style of clutch.
I found a Raybestos high energy clutch disc, R572250, but it's not a waffle cut, just a black high energy friction.
Ok I learned more today about wet clutches than I ever wanted to know...
In the end, we found the exact same clutches I pulled out in 2019, which were the Alto "black" with a Radial or sunburst grove pattern. Not a waffle pattern, nor is there any waffle pattern options available besides custom orders. However after some research, waffle is probably not the best pattern for this power application. Thanks for all the help Brad![]()
For those interested in more details on the why and how of clutch patterns, might I suggest this short engineering comparison.
Parametric analysis of wear factors of a wet clutch friction material with different groove patterns
