Mph is very much affected by your launch. If you spin on the line your mph will be faster.how are ya figuring? mph usually doesnt care about your launch...
I’m not understanding how completely flat footing off the line would give the same speed at the end of the 1/4 than a launch would...
NA 5.3 with mods would make 450HPish at the crank, 14psi of boost with the parasitic loss of the supercharger should around 300-350HP gain, then 20% powertrain loss should put you around 575-625 Wheel HP.
Yep, your right, a 5.3 at 14lbs of boost with heads, kooks and high flow y pipe makes 550...:rofl:
From back on the other pageStock cam?
I forgot about this thread. I built the top end with BTR stuff, added a stage 3 boost cam, no more AFM or DOD, got 105 ID injectors, pinned the crank pulley, did a few oiling upgrades and retuned it for 14lbs. Truck spun really bad on the rollers so I played with it at the track a little. No launch just flat footed it from a 700 rpm dig and it went 12.5 at 110 weight is over 5300. Tuner figures power is a tad over 800 crank with performance numbers and fuel trims. It's a blast to drive, I have put over 20k on it this year alone.![]()
Flat foot, no boost launch will net you a higher mph and slower et. Boosted launch will net a slower speed but quicker et. Assuming no traction loss.
My 6l80 is upset, time for a new one or maybe a build. I'm not sure yet going to trans shop in the morning. She is still going just upset on the 2 to 3 shift under boost. It's still shifting but free revved on me this week for a split second before jumping into gear and blowing the tires off at 60 mph. That wasn't cool, need to fix it before it blows everything up.
