Driver’s side rocker
I thought the budget undercarriage coating was wax and gasoline. The gas would evaporate leaving a wax coating behind.
How long does the used motor oil formula last?
Did you use the GM auto t case fluid? They use a special kind of fluid not the normal kind our trucks take
Autotrac uses the blue smurf fluid, otherwise the viscous coupler can fail as well as the shift fork chew up. GM came out with the autotrac fluid after the autotrac case came out. Dex vi is not to be used in any transfer case as per GM. Dex vi is too thin, you're supposed to use there manual trans lubricant(aka dex iii or dex/merc fluid). Dex vi will take out any transfer case.
my bet on the antilock light,,abs motor.had that happen twice on my 02.nice score
on the rust proofing,,used oil sprayed on,then drive on a dusty road.
