All I heard was bolt on...:rofl:
yeah well, im pretty sure your the same one spamming the site with viagra/porn stuff too :roflmao: :hug:
Will the 2020 oil cooler work with PPE manifolds?
Will this cooler work with pro fab manifolds? Seeing how there is not heat shield on the manifolds I’m assuming I won’t have an issue, but I’d rather not assume.
From what I gathered in your post, you stated it was a problem with LML manifolds. Apologies.
Josh's shop is going to order me a new 2020 cooler and send it up my way. Going to try it with PPE manifolds and my external air-oil cooler as well.
Will check back in 3-4 weeks from now once I have everything.
y'all buy one and let us know. you will have to look at the pics i and josh have posted and judge for yourself. i would say yes but thats not a for sure answer
I E-mailed Bat Inc who makes the adapter on the oil filter housing to see if they make the same male-male threaded piece in the M22x1.5 threads. I am hoping they do, as this will be easy to replace.
If not, I will have a local machine shop make me one.
the sealing diameter of your sandwich adapter will be too wide as it is. you will need to either make an adapter plate or use a different sandwich adapter. already tried this on my own external air to oil cooler with the new 2020 oil cooler.
Crap! I see the old filter OD is 88mm and the new is 72mm. I was hoping there would be enough material on the cooler to make it work.
Do you happen to have or can get the measurements for the cooler oil filter sealing surface? OD and ID?
Did you happen to have aftermarket manifolds with the 2020 cooler?
no you can not. you will have to either make your own adapter or buy a whole new setup. i believe there is only 1 or 2 options for -10an sandwich adapters in the thread, none in -12an. never could confirm if diameter would be correct.
hehe none in -12an? Thats about to change![]()
I have yet to see over 220 on my oil temp gauge since doing the swap hauling a 2015 GMC dually on my 24’ bumper pull trailer (probably around 21k lbs gross between the truck and trailer). That load would normally see peak temps of 240-250 with the factory cooler, but I am hesitant to compare temps because I had to move my temp probe to the pan with the new cooler. I need to get an adapter sorted out so I can put it back in the cooler housing like I had it before reading pre-cooler temps. On the highway, it is usually showing around 180-190 where before it was usually around 210-220.
