How are you guys getting your hands on the 2020 coolers?
I was told 6 months away!![]()
canada is a different deal than the states
I've been fighting with a dealer all day and not getting anywhere.
Would anyone be willing to purchase one for me and send it to me if I paid before hand?
Thanks
What is the new oil filter part number? I want to see if I can use this new cooler with my thermostat off my oil filter housing for my current air to oil cooler.
**EDIT** Found it a couple posts back.
New Filter: Thead size M22 X 1.5 (93mm Diameter)
- Wix: 51592
- Donaldson: P550166
Old Filter: Thread size 13/16-16UN (94mm Diameter)
- Donaldson: P550518
Are you able to remove the threaded end inside the oil cooler and swap back on the original M22x1.5 threaded filter stub? I am running the BAT MOCAL SP2TC oil filter adapter plate with thermostat and fittings running to my air-oil cooler. This new cooler will not work with the new thread size.
- Wix: 51592
Has anyone tested the improvement with a LML cooler upgrade? Seems like that is a bolt on upgrade with a decent area improvement vs. this new one that is a LOT more work. For a LMM doing heavy towing on a mild tune, would the LML upgrade be the best route?
I'm curious how you see it as a lot more work? You bolt this on with new bolts from the dealer and have to do some minor shaving on the exhaust manifold heat shield bracket if you're running LML manifolds. The LML oil cooler is identical as to what came on your truck. 17-19 has ~40% more cooling capacity (14 row vs 10 row on 01-16). 2020 has 20 rows offering an awesome 100% increase in cooling capacity.
Ok, so it may not be A LOT more work, but if the other one bolts on that is certainly easier.
They both bolt on just as easily as the other. The new one simply requires in additional bolt for the coolant adapter where the coolant leaves the cooler body. It genuinely is no extra work at all! :hug:
you guys will have to shave the lower rear heat shield mount regardless of lml exhaust manifold or stock. it does not just bolt straight on, if you left it, and cranked the bolts down, it will crack over time.
does no one read anymore? or is it just selective reading?
josh posted his needed it as well.
