Large lift pump suggestions?
M.A.M.
429
Ohio
I'm needing a larger lift pump than what I have right now, which is an AD-165. Haven't had any issues out of it at all, wouldn't mind sticking to AD, but was told I'll need a Fass-290 for my fulel setup. As far as I know, AD doesn't have anything equivalent? I looked at Fuel Lab and Kennedy, but neither seem to offer anything in that size.
Is the Fass my only option, or would running 2 ADs in-line do the trick too? Any pros/cons to running dual pumps?
Is there anything else out there I should consider?
M.A.M.
429
Ohio
I will need a larger one if I want to max out the fuel/air. Fueling is 200% Exergy injectors, and a 14mm stroker. How much is the AD-165 good for?
KRODMAX/KS
It'll be alright
Jul 27, 2017
177
22
Oz
My understanding is that the 165 is supposed to be good up to 800hp.
M.A.M.
429
Ohio
I’m hoping to be well over 800.
What is the FuelLab 200 rated for? I’d much rather go with it, than Fass.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Buddies truck is at 1200+hp with his. Witch is gonna be about max for your injectors.
Baldwin makes fuelab filters.
My new build has fuelab 200 with 400s and 14mm pump.
M.A.M.
429
Ohio
That’s about where I’d like to be. I’m leaning towards FuelLab since it’s brushless, and I’ve heard nothing but good things about it. I’m thinking that should be all I need. Appreciate the info...
M.A.M.
429
Ohio
Are you using a sump with the FuelLab, or does it work with the factory draw straw?
M.A.M.
429
Ohio
G&R Diesel is just a few miles from me, might have to run over there pick one of his up.
1,514
Fuelab 42401/42402 both need bypass regulator -10 supply line
I have a 41402 for my 8.3..should have done the 41401 at least I don't have fuel starvation issue :rofl:
4,847
1,894
You won't run the Fuelab pump out of fuel. Tim Jahn has made well over 1200hp to the tire and hasn't had any fuel pressure issues (6.4L Ford running a Velocity 200). Get a good sump (G&R, RCD, ect) and be done.
You can use a Hobbs switch to control speeds. I am using an adjustable Hobbs switch set at 10psi which will open the ground to the speed control terminal. Cuts down on noise and unnecessary pumping of unused fuel.
Is this what is being referenced?
https://fuelab.com/products/diesel/...city-200-gph-airfuel-separator-gm/item/30304/
What filter and seperator would this take besides OEM Fuel Lab filters?
See my attached image. Ask and you shall receive!
I'm doing the same thing. I went with a Prodigy 41403 (200gph @ 20psi) with a bypass reg mounted underhood where the driver's battery goes. I'm running modded 250% with a 14mm street pump in the valley and a stock LBZ pump on the belt all fed by -8AN pushlock.
Fuelab 42401/42402 both need bypass regulator -10 supply line.
^This
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
I ran a Fuelab 200 with a bypass regulator feeding 2 10mm pumps and 150 injectors on my LB7 pull truck. Truck had dynoed 1252hp at the wheels and pump had no problems keeping. Fuelab pump motors are also brushless. I ran it for 3 pulling seasons with zero issues. I will be definitely be upgrading my current truck to a Fuelab soon.
M.A.M.
429
Ohio
Is the Velocity 200 lift pump self priming? A Velocity wouldn’t need a bypass regulator either, right?
4,847
1,894
Correct, a Velocity does not need a separate bypass regulator as it has a regulator on the output plumbing that is preset between 8-10psi. You will have to run a return line just like a FASS or Airdog.
I can't comment on self-priming but you should be filling filters now upon changes in order to stop the lift pump from running dry.
