Here’s the ratios,
First number is the 6 speed the second number is the 10 speed.
1st 3.094 4.54
2nd 1.809 2.86
3rd 1.406 2.06
4th 1.00 1.72
5th 0.711 1.48
6th 0.614 1.26
7th 1
8th 0.85
9th 0.68
10th 0.63
R 4.48 4.54
Cool. Thanks. Those look nice.
Here’s the ratios,
1st 3.094 4.54
2nd 1.809 2.86
3rd 1.406 2.06
4th 1.00 1.72
5th 0.711 1.48
6th 0.614 1.26
7th 1
8th 0.85
9th 0.68
10th 0.63
R 4.48 4.54
9th and 10th sure are close
Everything I've read says it can skip shifts. I forget where I seen it, but I read where it said it can jump multiple gears at once during downshifts to cut down on the lag currently experienced. As to swaps, I'm sure it will be possible, but it appears this trans is quite complicated internally, and finding a suitable controller may be an issue. But most of the info I can find is on the 10l80, not the new big boy.if you can get into the TCM and develop a skip gear tune (assuming it can happen on this trans), it may not be an issue. it would actually give you alot of possibilities to keep the truck in a good power band down the track but skipping useless gears due to the upped power.
skipping will depend on the internal design and how clutches are applied though.
. . . . . . it can jump multiple gears at once during downshifts to cut down on the lag currently experienced.
You need the tcm tuning that I'm running then or something.. Mine shifts as soon as I stomp it, matter of fact it down shifts when I don't even want it to sometimes..This is what I am hoping for. When I floor it, I have to write a sweet little love letter and mail some roses, hoping my dear sweet Allison gets them before they die and she decides to downshift. . . .
That’s what makes me a bit apprehensive, I don’t want to roll into the throttle a bit and have it downshift when it doesn’t have to. That’s one of the main things I like about the D/A combo, I can be pulling a pretty good sized trailer and roll into the throttle on a hill and it will maintain speed and not downshift. Basically I’d like the exact same shift parameters but when it does need to downshift it does it right now. Maybe that tuning is available, and I’d be interested in it.
I think this is going to be a busy trans and that's not a good thing. From the cut out, it looks like a chain driven pump. If so, that means it's going to be a quick shifter and I assume it will be in 10th gear by 45-55 MPH for better mileage. Hopefully they get the software right for decent shifts. For street driving I would think 2nd gear would be a better start off gear.
I thought the chain was just for the PTO?
