The new model Duramaxes always seem to bring out arguments like this. Been that way since the LLY came out.
We'll see what we'll see on the L5P.
Some of you guys must not be towing 30k.. :hug:
I guess Mark should have tried to talk me into one of these single master tunes instead of a dsp
Oh and the single 80mm turbo having a progressive power band :roflmao:
There are several legitimate reasons to have a true DSP5 switch:
On a mileage tune for running empty you can get away with a little more timing than a tow tune run under load, and it will help the mileage. On VVT trucks you can also open the vanes at cruising mm3 to help the mileage when not under a load. Those things would both not work well while towing heavy loads.
Running on a high power tune will mean that you use less throttle input when driving conservatively, such as while towing. With light throttle comes earlier shifts, earlier shifts while towing will get you under the turbo. On a lower powered tune you will have to use more throttle while towing, effectively raising the shift points and making the truck tow nicer. Sure I can manually shift at a higher RPM, but many customers don't want to manually shift their automatic and why should they have to. Some people get annoyed by a turbo brake except when they are towing, so having it only on the tow tune is nice.
While racing if you are not full throttle (for bracket or what the track can hold) you are also going to have a lower shift point and a hard time staying consistent for bracket/index racing. A switch lets you run a tune that will run the number while WOT with shifts at a consistent RPM.
A low power tune for if someone else drives your truck is nice. A high idle tune is convenient for low speed cruise control (towing a camper through an RV park without your foot bouncing on the throttle), jump starting someone, warming up your truck or cooling off the interior faster, etc.
Not that I can recall. I have spun my tires in the rain and snow before, but that is because I was trying to accelerate as fast as traction would allow. I was slowly easing into the throttle until I broke traction, and then backed out. I could have easily done the same thing with a stock tune under the same conditions. Stock LBZ turbos are pretty predictable on boost, and even the 76mm single on the shop truck is pretty predictable and easy to drive. As a matter of fact, I don't even have a switch on that truck, and I drive it all the time on the tune that ran in the 10s at 128 mph. I would be happy to let anyone go for a ride in it if they are close by.So you can tell me you have never been caught off guard spinning your tires when you’re rolling into it, because the boost hits in the rain, snow, or ice? I feel you can make the throttle as progressive as you want our power band still won’t be progressive. And for someone that’s not used to it or worse yet only driven vehicles with traction control it’s dangerous IMO. Of course I might be a little bit biases since my wife could’ve easily been killed in her accident due to her lack of throttle control.
Or definitely not towing 10-15k through the mountains in the middle of winter when it’s -20.
Sure a guy could flash a tune in but when a one leaves Calgary and it’s 45 degrees you don’t really think about the temp 3 hrs away when you and 3 buddies are loading up the sleds for the weekend!!
Yep, but gotta add a couple things. Try leaving the truck on the max effort tune when it is more like -35 outside. Even being plugged in all night doesn't help. Oh sure, it starts right up but have you ever listened to a max effort tune Duramax just idling or driving at these temps. Now lets hook up 10-15k behind and head to the mountains. I turn mine down to stock if for nothing else than my ears and stress level. It might not be hurting anything but that is not what it sounds like.
just my two cents.
They still sound like a 7.3 till they warm upInteresting isn’t that what ect and iat multipliers are for :spit:
Sent from my SM-J337A using Tapatalk
The "I need a DSP5 switch" starter pack
I just traded out my 2016 Denali LML for a 2019 Denali L5P.
My initial impressions after driving a 100% STOCK LML for almost a year is that the L5P is a big improvement IMHO.
I have owned or driven them all, owned new a 2002/LB7, 2007/LBZ and driven a ton of LLY and LMM and have also owned a 2012/LML - Tuned/SOTF, 2016/LML BONE STOCK.
IMHO I would delete an L5P, remove some of the limiters, get it to about 500 honest RWHP and around 1100 for TQ, Max the TCM Line PSI out and leave it as a single tune.
The trans should live and it will last a good long time.
The guys that want to spend $5k on ECM Tuning, $1k or so on TCM Tuning, $4.5-$6K on a full built trans, plus a downpipe/install labor, under-hood pipe kit/intake, and a full exhaust, IMHO you are approaching north of $12K to delete a truck and do what has been done to previous years.
Granted a lot of guys build a trans, do a under-hood delete anyways, but the stock truck is pretty healthy by stock truck standards, I have not towed with mine yet, but on tip in and stabbing it I can tell its better than a 50-60HP LML deleted tuned truck just stock.
I have my spare ecm and tcm.........so we shall see what I decide to do.
