Just figured I'd post up on the set I've been running. I had 2 injector body's fail on my way to meet someone who was buying my truck. Call it luck or what have you but that cost me a pretty penny! So after everything was said and done, I ended up with a set of Exergy 45% overs with the SAC nozzles, I also installed a brand new LBZ CP3, C grade gaskets and ARP head studs. For lift pump I'm running a FASS 150 and a CAT fuel filter on the factory filter head. I have PPE up pipes and manifolds, other then that I still have the stock turbo a built trans by Mike L. I Now have little over 30k miles on everything in the motor and a lot of hard towing miles. I'm extremely happy with everything and the guy who tunes my truck actually likes them better. I clean my injectors out ever few months and my fuel filters are changed every other oil change just because I'm anal about it. As far as performance goes mine are turned down since I still have the stocker turbo /: but I will tell you at WOT they are very quite compared to any OEM reman injector.
If Anyone has questions let me know! I just installed a set of S&S 45 over SAC's in my buddies built motor LB7 so we'll see how they are compared to mine. Should be the same since it's the same guy who designed mine
