What's the best way to get ahold of Levi?
If it blew it wouldn't suprise me no. But sometimes you have to take risks, which i am doing lol. I think the fact that the truck is 5340 pounds helps for sure. And I'm always in the high rpms which helps. I dump it at 4400 and it doesn't go under 3k if the boost is up from the rev limiter. Just rolling the dice and getting lucky so far.Okay quick question for the inexperienced here. So you're putting down around 750hp and making 11 second passes on a stock bottom end.... does it hold together because the zf or are you just waiting for it to exit the block lol I realize that may sound like I'm calling you out but I am not by any means. I've been following this thread and your other one for a while and that some impressive work.
Levi still making a good turbo blanket? Or is there any brands that I should look at?
Just put one on my lbz two days ago. Absolutely fabulous product in looks and quality!
Ah I see. Makes sense :thumb:
I wanna see if a blanket and sneak me a few more pounds of launching boost and maybe see if mark can't make something happen to get a few more pounds out of it on the limiter.
Diverter valve possibly? I have no experience with them just a thought.
You might try the orifice deal I'll mentioned
This is too cool!!
You do have caltracs, right?
Any mods to the zf6? Short shifter? Ceramic pads - is that SBC recommendation for what you're doing? Not questioning it, just curious & learning. :thumb:
This is too cool!!
Congrats man! I've watched you beat and build the truck for a while. Nice to see you reach your goals!
