When I made the dyno tune for my transmission, I discovered that EFILive has mis-labeled the modes, badly! I wrote down what they really are, but can't find the note at the moment. I'll look when I get home. Once you know what the modes actually do, it works great.Must be nice having a 6spd! Of the 3 files I have ran, I had to change the shift speed to zero mph in every mode for it to respond. So no regular / TH mode split for me so far![]()
4lo and TH are swapped!
So did you do a test hit yet ? What's your Butt Dyno tell ya ?
That would be awesome! Out of all the old threads I looked through for shift point adjustment and 2nd gear tunes this was never mentioned (that I saw). Wouldn't it be really easy for EFI to fix that?
Is that for everything? Wot shift points too?
I don't know how you guys figure stuff like that out, I'd be bald from pulling my hair
Columns B and D are swapped on all of them from what I can tell! I usually set all of them the same so I don't have pull my hair out and cuss. In other words, I set Normal mode the way I want it, then set b,c, and d to the way I want TH mode to act. I never use 4lo so it doesn't bother me to have the columns set the same.
My truck tends to shift into first if I am rolling and not on the throttle. The second I pull in to stage and start to spool it always stays in second. Luckily mine only starts in second with tow haul on.
So Crenshaw, it should lower your 60' since you won't have that 1-2 shift should also help your 1/8 & 1/4 since your eliminating that 1-2 shift and the granny gear that moves us a whole 10-15 feet
LOL I figured it out. I made a change to the slip table and there's some kind of a glitch that FUBAR's part-throttle lockup in T/H. I used to run 3000rpm in that table (all three entries). When I did this tune, I used 8000rpm and it was the root of my problem. I moved it back to 3k rpm and everything works. I get 2nd gear start in M2 T/H only, and otherwise my trans acts exactly the way that it used to. :thumb:
Mine is in my Sig . Georend LL converter. In 2nd gear start it will stall to 3400--3500. Last run I made on Tune 3 the tires held . Question is will they hold in Tune 5 . We'll find out this Friday weather permitting.
