3,795
422
I'd still do a torque plate, just use an old set of stock head bolts at stock torque with the torque plate. It might not do anything, but if it does, you've accounted for it.
It is a bit strange that the ring gaps opened up that much. That implies there is a decent amount of ring wear going on. Maybe it is just the constant high load the engine sees, but that seems a bit quick, even with your use.
1,514
Are you going to detune it, Adam?
Definitely pullimh pilot timing back.
I really don't want to go substantially over 400 hp right now... while the trans has a jr kit and 280psi line spring in it... Also idk how much the transtar TC will take.. its just a beefed up stock unit with lower stall
How does the 41909 mahle rings compare to stock?
3,581
That's a good question. I never thought about that, maybe the rings are a softer material?
Straight from Guy Tripp:
Notice what he says about heat.
I myself am not too worried about running the 41909s for my application, but in Adam's case maybe its not a good idea?
8,235
That would make sense why the top ring ran away with wear vs second ring barely grew in ring gap
What about the 42160?
also explains why im not seeing lower compression or anything from mine since i bought my rings from Guy.
1,514
1,514
This paragraph makes my point. 2 or 3 weeks is because you rebuild them yourself. A long block can be swapped in a day if your working diligently. And a longblock doesn't cost anywhere near $10,000. More like 7000ish. And bam your back on the road.
Followed up on this.. dealer quoted ~7100.00 for long block and 2 weeks lead time..
Do bore balance and billet rods for that..
And seams you cant buy a bare block
S Phinney
4,008
Quncy, Fl
Using stainless or tool steel top ring would be what you should run in a high heat situation. Cast rings will not last in that environment. That is all I run. End gap being a little looser will not hurt anything either. Plateau honing is a very good idea as well. Mine are always plateau honed. You want and need a block that is prepped right and use the right rings. You will then stop having this issue.
1,514
Passenger side
all glow plugs in while doing the test
8 pulses/compression cycles each cylinder.
1: 360
3: 350
5: 300
7: 310
Getting ready to do driver side.. though 6 pack says ill see similar readings..
Forgot to post ring gaps
Took a piston and shoved them down until top of wrist pin was flush with deck
Old
1st .023"
2nd .024
New rings
1st .018
2nd .024
Both ring sets where mahle #41909
Id Say the .023" gap on the top ring allowed the carbon/gum up of the secondary causeing it to stick and increase blow by
Haha those are way tighter gaps than mine. I'm around .030 lol .009- .010 ptw
So do you think was causing the lack of power? I really don't think the ring gap is
Yes i think the ring gaps and carboned up LCR was 90% of my issue
Current compression test with new rings..
1 450psi
3 450 psi
5 440psi
7 440psi
Driver side mirrors passenger side and cylinders 5-8 take longer to stop building psi... My gues is due to intake manifold design and additional length it has to travel from the y bridge
