Welp start tracing wires. Check before and after the fuse and relay.
Also they are a bit short handed right now so just be patient.
Well, I checked the for power at the pump and no power was found.
Truck is running sluggish now, kinda pissing me off so I hope its soon.
well if there is no power at the pump, they probably wont tell you much more than what we are telling you. You really need to check that relay. if you have power at the fuses and all the power connections are good along with grounds, that realy may have crapped out
I've check the fuses, the relay, and where its grounded. I even took a car battery to it and nothing happened. Idk if the battery was dead or not but I did try everything. The fuses and relay have power but when i check the pump nothing.
so when the relay is clicked "on", power is coming out of terminal 87 correct?
As far as I know yes.
x2
But if you put power (12v) and ground direct to the pump and it didn't kick on then it's probably no good.
How did you check it? Not sayin i dont believe you but relays can be tricky SOB's sometimes
