It is possible that the benefits of ram air are being confused with the observed benefits of charge temperature control.
In track scenarios, sourcing air externally gets IAT down faster than other methods, significantly reduced with just 100 ft of travel.
I don't mean to be offensive with the word placebo. Just that for every observed improvement there is a reason. If the truck is not tune driven with MAF or IAT, then those are not likely causes. But for sure, air density is important, no matter how you get it.
I know Pat has multi-generational stock intake experience. The reason racers pulled the headlight (whether they were aware of it or not) is that IAT would rise waiting to stage. A run at 150 IAT yielded lower times than cooler IAT's. The reasons are not in dispute. Without the headlight removed, the intake tended to protect that temperature, increasing the IAT "latency". Remove it, and there was a source of cool air the moment you got moving.
We showed that an LLY benefitted on Grade the same way. Removing the headlight made a big difference on time to summitt.
Anyway, I stand by my statement, at the speeds typical of a pickup, the term "ram" is not one that comes with any real scientific basis, when with 30 psi forced induction. This is not natural induction, where ram benefits can be realized. IAT control is a different matter. Having logged an IAT of 243 F, I can say, it is big. You can lose 20% density with this alone.
