LLY: Type/Brand of Engine coolant
Wyley87
Jul 21, 2012
75
Texas
I did a a search before posting and couldn't find anything on the subject.
I have an 06 LLY with 75k on the clock and need to do a cooling system service as well as change both thermostats. I know the truck came from the factory with Dexcool but I read somewhere where Dexcool is not really made for diesel engines. What coolant should I use?
Sent from my iPhone 4s
Wyley87
Jul 21, 2012
75
Texas
I knew about there being no drain plug on the rad but I thought I read on here in the tech section that there is one on the drivers side of the engine.
1,601
That plug will still blow coolant in ten different directions when you open it. If you happen to have one of your I/C pipes off, use that over the drain to funnel the coolant into your pail.
S Phinney
4,011
Quncy, Fl
Mix it 50/50. I use two gallons of coolant but I am in Florida. Should still be good in colder climates though.
Wyley87
Jul 21, 2012
75
Texas
Well I'm in Texas so I will be mixing 50/50.
So I need 2 gal straight coolant and mix it with 2 gal water.
Wyley87
Jul 21, 2012
75
Texas
I got a little 3x5 pan so I'm hoping to catch most of it lol.
I've always been kinda leery of dexcool also. But being the first diesel I've worked on I wasn't sure on type of coolant. I'd like to just put green in it cuz that's what's in the rest of my cars/trucks.
4,933
when i put my motor back in i swapped to the green coolant. jsut bought the normal off the shelf stuff.
