Let’s start with 2002 Chevy 2500HD 6.6
I am chasing an issue I am sick of. I came to a red light and went to go and my truck would not move in drive. It did go in reverse so I was able to back up into a parking spot luckily. Get it home, disconnect battery and it still only had reverse. I replaced the NSBU switch and totally messed up, it would only start in neutral. So bought a new one and wiring harness and no luck. Changed transmission speed sensor. Took the steering column apart tonight to see the tow haul wire cut in half? It doesn’t even look broken, it looks cut. I spliced those back together and tow haul light popped up showing me it works. Put the truck in reverse and it locked in and moved. Tried drive and it would not move. Went back to park, tried reverse again and on the dash it was showing I was in neutral instead of reverse. Went down one to neutral and the R on the column was blinking. Back to park, went down to drive and drive started blinking. I noticed the transmission shifter interlock solenoid looked loose so I pushed on it and D stopped blinking, and it also went into reverse fine, then I went to drive again, back to reverse and it wouldn’t work then.
So if I pull the shifter down 1 from park it goes into neutral, pull it down 2 it goes into reverse and blinks, pull it down 3 it dies into drive but no engagement and does not drive, pull it down 4 it’s in 3, pull it down 5 it jumps to 1st, pull it down 6 it goes to 2 blinking.
Do I have something backwards on the NSBU?? I feel like after I spliced the tow wires together, connected the battery, it reset something for just along enough to go into reverse and threw itself into limp mode maybe? Even disconnected the battery does not do anything or allow it to go into gear so me messing with those wires under the steering column made something happen…
