Stalling lb7
Ozzy57
33
Attached. Looks like a power or ground problem. TCM detects power loss from battery supply at ignition off. Check your harnesses, grounding, and TCM connections.
One thing that comes to mind is it has a lbz fpr and I had to bend the fuel line a little to clear the lb7 connector. I’ll check it out .
Ozzy57
33
I'm betting it's transmission related
If it is it has to be wiring the trans is a built suncoast with triple lock converter and billet flywheel. It was built for 1,000 plus Hp . Nothing was changed on it and it wasn’t pulled when the old motor was . It has 30,000 miles on it . And the motor is all new . I’m going to drive it and data log as much as possible. Hoping I’ll catch it stalling and get some useful info .
Ozzy57
33
It was the ground off the harness at the drivers body mount . It had separated inside the insulation! There are three wires there . Hasn’t stalled once since I repaired and cleaned it .
Reactions: dndj
Ozzy57
33
Unfortunately it did it this morning stalled turning onto road said shift range inhibited. Went 20 miles and it stalled turning left into a school said service brakes soon . Then turned into restaurant left again stalled but no info this time ? Wtf
Ozzy57
33
Pull codes, including TCM. Post them here.
There are no codes ! That’s the problem! Fixed a ground on the passenger side that looked ok . But upon repair it stopped the stalling.so far so good put 100 miles on it today
Ozzy57
33
Thank you ! Ended up being the black with white stripe ground wire on right front of block . Pitman arm was rubbing and pulling on it when I’d make left turns . Then it would kill the motor . Wire was pulled in two inside the insulation.
Ozzy57
33
Thank you ! Ended up being the black with white stripe ground wire on right front of block . Pitman arm was rubbing and pulling on it when I’d make left turns . Then it would kill the motor . Wire was pulled in two inside the insulation.I have a aftermarket brace on the idler and it’s close there with the stock set up . I clearanced it .
