Does anybody have a banks big head waste gate actuator and did you notice any power gains or egt drop?
Just installed one. Havent made any 1/4 runs to find out if anything changed.
No noticable power gain or egt drop just everyday driving though? What psi did you set it at?
Id love to replace or get twins but I don't have the funds at the moment I used to have mine unhooked but I was told two thing by different people #1 it will overspeed the turbo and cause failure #2 unhooking the line will bleed of quite a bit of boost therefore gaining nothing. Which is true?FWIW the stock turbo at 30 PSIG is running so far off its map that all youre creating is excessive heat. Whatever power gains you would have from the increased boost pressure are offset by the excess heat. Also, from my expirience, stock IHI turbos dont like to live much over that 30 PSIG either. I killed 2 of them within 2 years at 32-33 PSIG. IMO if the stock turbo isnt enough for you either replace it or give it a bigger brother.
For those of you who like a bleed orifice, or adjustable "boost valve" try this expirament: unhook your wastegate signal line completely. My bet is that you will not see more than about 27 PSIG of boost anyways unless you have a very heavy fueling tune/chip. This is because the stock actuator spring is not strong enough to hold back the amount of drive pressure required to create that boost pressure.
GM/Isusu almost did to begin with...this turbo is grosly undersized for this engine)
How many turns did you give yours and do you have an IHI or Garrett?
grossly undersized?? I disagree. You can do over 500rwhp (double stock) and run 12's with a stock duramax LB7 turbo!
Try doing that on a stock cummins/7.3/6.0psd turbo. If you think the duramax has a "grossly undersized" turbo, go look at what the cummins guys have to play with.....
