I've been through that harness with a fine tooth comb
Z Zstarkey New member Oct 17, 2021 12 0 1 Oct 19, 2021 #21 I've been through that harness with a fine tooth comb
2004LB7 Well-known member Dec 15, 2010 6,387 1,751 113 Norcal Oct 19, 2021 #22 like I said earlier, if you are sure of the injectors and harness then the only thing left is the FCIM or ECM. do you have a friend or someone you know that you can swap them out with to test?
Z Zstarkey New member Oct 17, 2021 12 0 1 Oct 19, 2021 #23 Unfortunately no I do not I would have to just send it out to test or fix
