worth the purchase or no? sorry for asking a lot of dumb questions on the site, just trying to learn and find out as much as possible. tried using the search but didnt really come up with anything. thanks guys
:rofl:
Trent
There were no boost valves back then. Stone age technology that works.
A boost pipe like PPE sells "fools" the wastegate into opening later. LB7 chargers do OK up to 32psi, but as go further the lifespan drops rapidly as you go higher. By the time you hit 40PSI, it's about 100% failure rate.
Most the big LB7 tunes will run more HP if you can turn the charger up to 30PSI or so, and are fueled accordingly.
