Oil prime
1,675
Do these have that disc that sits in the center like the earlier Versions???
Any Damage to the convertor???
3,149
Those look like fatigue cracks due to constant flexing. Id make sure the transmission was seated to the engine correctly and flush. Also no debris or anything stuck between the converter and flex plate or transmission and engine. Just a small amount of continuous flex due to a misalignment can do that
ikeG
Oughta Know Better
Apr 19, 2011
2,557
191
Western PA
www.facebook.com
I didn't see any issues taking it apart. Not sure what to think
Sent from my SM-G990U2 using Tapatalk
3,149
Loose converter bolt(s) is my next guess. But you already mentioned those
3,589
I can remember seeing that on higher-hp trucks in the past, but not stock. Did anything else seem odd when you took it apart again?
EDIT: you answered that earlier.
Must've just been fatigue from use.
ikeG
Oughta Know Better
Apr 19, 2011
2,557
191
Western PA
www.facebook.com
Washer
8,237
Any idea where the heat marks on the flex plate came from? Theres two spots that look like they got hit with a torch. Could have harden there, cracks started and bye bye
ikeG
Oughta Know Better
Apr 19, 2011
2,557
191
Western PA
www.facebook.com
It does look like that but that could be from the friction while running it. He actually drove like this for a while, towing snowmobiles. An employee did this job from start to finish in Aug, he's quit Dec 31. But even if he took a torch to the flywheel bolt heads I don't think it gets spots like that.
13,882
993
I think James is on the right track. I bet your former mechanic heated the bolts with a torch and got a little wild with the flame.
8,237
Definitely a “who came first, chicken or egg” situation. I can see how it could be either way. Since it junk, could try hitting it with the mapp gas and see how long it takes to turn it color
3,149
While they do look like heat marks, the HAZ looks too small or narrow to me for a MAP gas torch. Maybe a quick mig or tig on the backside. But that would be obvious.
Maybe take a sharpened punch and with some light hammer taps, see if any of those spots seem harder or softer then the rest. Not too accurate but maybe enough to tell the difference
I'm going to stick with the transmission not being perfectly flush with the engine.
3,149
And this is after map gas torching directly on flexplate for 20 seconds
That is more what I expected the HAZ to look like. The previous one is too small makes me suspicious if it even is heat related
Can you tell if there is a hardness difference between the torched areas and unaffected?
8,237
If the guy held it sideways to get the side of the bolt, the heat would line up with the flame direction
