It's no different than coolant temp... You read it before it gets cooled not after... On the basics...
That makes no sense at all.
This....there is no way I'd get that cooler in the bumper and I have a bigger road armor bumper. I know horizontal isn't ideal but that's why I did one with a fan. The vertical options left the cooler hanging below the frame.
Maybe I can make scoop or something to try and get some air flow going through it? I thought the fan would make up for the fact it doesn't have direct airflow.
anywhere under the truck will have turbulent air which means you are 100% relying on the fan to do all the cooling. its best to keep it out of anywhere the air can come up and start circulating around as well because the fan will just start cycling the same air through the cooler. I have my fuel cooler mounted just off the frame, parallel to the frame (wont fit in the factory fuel cooler spot). it has a cheapy 1000cfm fan (doubt its that much cfm) but it seems to work and i can manage fuel temps.
i would suggest upping your fan to something like mine. the Spal 12" 1650cfm fan. I have my oil cooler mounted in the front now but its about 30* from horizontal. im limited on space up there BUT mounting here lets high pressure air from driving down the road hit it and then the fan to suck it through. Having the much larger rad and aux rad has combated the little loss in air flow over the cooler as the water to oil cooler works much better now.
again, rooftop, i dont feel this will fix your issue. you need to get those coolant temps down. what fan clutch, thermostats are you running? whens the last time you pulled the cooling stack apart and degreased/cleaned it? you have no boost leaks correct? how hot of a tune are you pulling on?
Speaking of fan clutches, who has the best? Mine sticks on 90% of the time on my daily.
Oh hell I'll take that one off your hands :roflmao: most clutch fans done come on soon enough I've been through a few bad ones, I had a Kodiak clutch that worked well and came on early but it failed fairly quick
I'll insert a plug for Kennedy's fan clutch here I guess. With no other modifications done, and replacing a clutch that had 220k miles on it, which would stay coupled when cold but uncouple and stay uncoupled during most driving when warm, we saw an immediate 2mpg increase and obviously cooler ECT and TFT temps when at operating temp. It's been on for 2 years now and has been pretty consistent in all ambient temperatures.
I hate this forum, Mine has been acting up off and on, and the truck is apart, so guess what just happened.I'll insert a plug for Kennedy's fan clutch here I guess. With no other modifications done, and replacing a clutch that had 220k miles on it, which would stay coupled when cold but uncouple and stay uncoupled during most driving when warm, we saw an immediate 2mpg increase and obviously cooler ECT and TFT temps when at operating temp. It's been on for 2 years now and has been pretty consistent in all ambient temperatures.
That makes no sense at all.![]()
that big ass bumper is doing you no favors in the cooling department....
It’s not, gm has cooling ducted through the stock bumper which now becomes blocked by your bumper. It’s not a huge issue but all these little things add up
I want to see if I can get one of the new 2020 L5P oil coolers and see if it keeps oil temps more in line with coolant temps. Mine will go 40 degrees higher than coolant on a hot day pulling a good size load, and it causes my oil pressure to suffer. I'm sure my engine isn't happy running 30 psi at 1800 RPM with 20k lbs behind it.
