not a dmax but a 6.2 in a 85 k10 sc/sb
ChevyTruckGuy78
Twins done Now for trans
Feb 7, 2010
694
Ct.
ok i had most of all this stuff laying around
dana 60 front
10.5ff rear narrow dually rear to fit duallys under stock bed
th400
np208
8in lift w/shocks
16in rock stars
245/85/16's
wh1c turbo
and a 6.2
all manifolds and pipes to hook up turbo
new mounts
anyways im wondering if anyone can help me out with this. im wondering if the 6.2 is even gonna spool this turbo and if it can spool it what psi should i run will the motor even hold up and so on
DieselDummy
Dirt Dummy
Oct 13, 2011
238
NY
What you need is a he351 from a 6.7 cummins and use a manual controller or go hytech and use a flees standalone controller.
Sent from the road!!!!!
03 lb7 CC/LB
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
From what I found on your turbo choice, it will be a horrible choice for reliability. It will be laggy, and produce way to much boost for even a 6.2. Remember you are dealing with 22:1 compression ratio here, not 18:1 or lower like modern diesels run. Keep the boost down to under 12 pounds with a free flowing turbo would be my choice. For a cheap set-up, go with a GM-8 turbo from a 98-00 truck. They pull good up to about 2400 RPM's, but beyond that the turbo becomes to restrictive. Head over the site I linked to as the guys over there are still playing with the old technology and doing mighty well with it. Theres also some turbo talk going on over at DP, but I would take many of there opinions with a grain of salt(unless you want to shorten your rods).
3,688
244
I have an old 6.2, and know a bit about them. Don't know anything about that turbo, though, so I can't say if it will spool or not.
As for boost, I've heard they hold ~12 psi just fine, but anything above that is starting to get risky. Probably depends on how much timing is added (if any). Marine injectors might help it live longer at higher power too.
Also, from what I understand, a hopped up 6.2 still can't hold a candle to a stock duramax. So don't expect it to be some crazy monster or anything... at least not for very long
ChevyTruckGuy78
Feb 7, 2010
694
Ct.
i dont ever expect it to match my dmax i just want it go be ablt to get out of its own way the wh1c i have been told is very similar to a hx40 but i could be wrong
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
The WH1C is identical to an HX35W and was the precursor to it for teh CUMMIN's. They like to run boost numbers up around 18-20 even on a 6.2/6.5. Also the 6.2 isn't going to be a powerhouse and EGT's wil lrun high if you turn it up much due to the precups in the 6.2 heads. If you want to be able to push it a little harder, look for a set of 6.5 turbo heads with the larger pre-cup holes in them.
ChevyTruckGuy78
Feb 7, 2010
694
Ct.
well found the downpipe on summitt and gonna go with the stock intake not gonna mess with the penisular diesel one but some people been telling me to switch to the marine injectors but havent told me what the diffrfence is i was just thinking of just running as it is. i have a new 6.2 block that has 60k on it that was removed due to a broken flexplate and maybee build up it came free with another truck i got i can never just leave well enough alone like i been thinking of a bigger set of turbos for my twins then dual cp3's and bigger injectors then that brings me to having to do rods and so on and then i just get sick of the thought of the amount of money its gonna cost and i forget about it all
