WOWThe BBQ Special LBZ ECU I purchased for our experiment... post #980
LLY Ficm
I'd like to see how they integrated the injector driver circuit into the LBZ/LMM ECMwww.duramaxdiesels.com
LLY Ficm
The VIN can be changed with EFILive, allowing Rob's tune to load after a VIN license is purchased?You can change the vin on the ECM using the scan tool. But if you want to load a tune, you'll need to license the ECM
YesThe VIN can be changed with EFILive, allowing Rob's tune to load after a VIN license is purchased?
Unless the tune is locked to the ECM's serial number.Yes
Use the scan tool first to change the vin. Then license the ECM and load the tune
I don't remember that? Seems like just the VIN. But hell, that was (9) years ago. LOLUnless the tune is locked to the ECM's serial number.
Thanks .Yes
The tune from Rob has all zeros in the serial number field. I do not believe he used the serial number to lock it to the ECM. It did a full flash on the replacement ecm.View attachment 131204
It IS possible, although exactly when it was introduced, I don't know. It IS possible that the OPs tune predates the ECM serial number lock I suppose. I can say that my IdahoRob LBZ tune is not locked in any way...... So if I were to take a tune, restrict it to the SN of my ECM, and then send it to someone else, it would barf.
Well, that's good news on the Tune. Interesting that it still won't run though... Seems more likely at this point that there's a mechanical issue at play (unless of course you got the cosmic bad luck of getting an equally bad replacement ECM). No monkeying? no chance the crank and cam connectors got swapped? Stuff like that? Will it try to run on brake cleaner or ether (with glow plugs disabled for ether)?The tune from Rob has all zeros in the serial number field. I do not believe he used the serial number to lock it to the ECM. It did a full flash on the replacement ecm.
A spoon full of gasoline on the fuel filter has never caused me issues with the glow plugs and has always run smoothly and quiet. Much safer then etherWell, that's good news on the Tune. Interesting that it still won't run though... Seems more likely at this point that there's a mechanical issue at play (unless of course you got the cosmic bad luck of getting an equally bad replacement ECM). No monkeying? no chance the crank and cam connectors got swapped? Stuff like that? Will it try to run on brake cleaner or ether (with glow plugs disabled for ether)?
It does run on Cosby juice.Well, that's good news on the Tune. Interesting that it still won't run though... Seems more likely at this point that there's a mechanical issue at play (unless of course you got the cosmic bad luck of getting an equally bad replacement ECM). No monkeying? no chance the crank and cam connectors got swapped? Stuff like that? Will it try to run on brake cleaner or ether (with glow plugs disabled for ether)?
Yeah, I'm not there. But he did mention before ever replacing the CP3, it would run on just a touch of ether.A spoon full of gasoline on the fuel filter has never caused me issues with the glow plugs and has always run smoothly and quiet. Much safer then ether
Actually, not sure.What does the missed cam and missed crank pids show?
Or possibly a sheared pin?What's the chances it snapped the crank and now the cam/crank are out of reference? Does the balancer "wobble" when cranking or running on the sauce?
Agreed, certainly could be.Or possibly a sheared pin?
This is important on LBZ+ platform.Visiting tech showed up, he saw nothing that should keep the truck from running.
No codes, he was asked about cam and crank signals, response was he saw nothing of concern, didn’t elaborate any further than that.
He did seem to struggle with it being swapped to LBZ, made a couple references to LB7.
He talked about some stuff I’ve never heard of. “Matching the flow rates listed for the fuel injectors with was shown in the glow plug module?”
Not all, at most I've seen them pull down a set of 4.Again I’m not there, got all of this as a recap from the trucks owner.
But the hopes that a 3rd set of eyes would see something we missed did not prove fruitful
Visual inspection of the balancer shows no signs of a wobble.
Does it need to be removed to inspect the pin? I can’t remember.
When he told me early on it ran on ether, I kinda of ruled out a mechanical issue, focusing more on fuel and fuel control.
Still trying to verify that the ECM is even trying to send a pulse or signal to the injectors.
GM service information has no procedures I can find to test electrical signals at the injectors themselves.
Any one know of the correct procedure to test them?
Also if one injector goes bad, would it shut the all down?
