Did you look at B0745 and B0746 ??
yeah I tried maxing them out a while ago; didnt make any difference.
Trent it defueled just the same with your tweaks.![]()
Ill send you some logs in a bit.
ben
ben
Ben have you considered switching to LB7 electronics and swapping heads/injectors?
LBZ Swap? When did you put the VVT back? I thought both of the twins where fixed?
Also Ben consider switching to a non-DSP tune , I have ran into some funky torque related fueling Issue's run the DSP operating system , even in LB7's .
I'll send you a tune, don't change anything in it leave the PW alone... i'd like to see this resolved ben. I'll send it too you early this afternoon
Ben will have to change the pulse for his truck , he has 30% over injectors .
Ben, have you tried a different OS, just for kicks try *****1668 04 LLY converted to a dsp.
I guess its not a big priority to get it fixed ?
Nope![]()
