LLY: my truck's weird issues...revisited...again
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
46
slc tuah
Ben , did you ever try those tweeks I made to that tune ? Like I said that is just a start , after we see how it reacts to those changes we can dial it in further .
TrentNell
Jul 7, 2008
7,543
46
slc tuah
Also Ben consider switching to a non-DSP tune , I have ran into some funky torque related fueling Issue's run the DSP operating system , even in LB7's .
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
LBZ Swap :D? When did you put the VVT back? I thought both of the twins where fixed?
no my twins have always used the vvt as the small turbo. I like being able to use it as a turbo brake for towing, and to warm the engine up faster in the winter.
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
60
San Angelo
Ben, have you tried a different OS, just for kicks try *****1668 04 LLY converted to a dsp.
GMC_2002_Dmax
The Still Master
I suggested that a while ago, I ran into a issue with an LLY that would limit MM3 to 88 and would not fuel over that.
I swapped tunes from another LLY with the same OS, same segments and problem solved.
It is either a corrupt ECM, corrupt OS or a tuning issue.
If you need help Ben my offer still stands.
TrentNell
Jul 7, 2008
7,543
46
slc tuah
I am going to bump this up Ben , I never did see a log from the tune i made changes in ? I guess its not a big priority to get it fixed ? The changes made took 5 minutes and was just a "test" to see how it changed the issue .
and i have since found a few more changes that I am pretty certain will do the trick when it defuels at around 89 mph . And emailed that tune back over along with another non dsp test tune that has your pulse and timing tables in it.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
This morning I launched my offroad beetle into the air sideways at 45mph and rolled it 6 times down the road and then into a ditch. Im pretty sore right now and have a headache...so fixing my truck isnt really a priority as of right now.
ben
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
Trent I tried your base torque and torque limited tables and it seems to be better. But it shifts badly at part throttle, and you can see in the logs the main rate is still jumping all over the place. (only the defuel isnt actually felt because of the tliq and base torque tables)
The weird thing though is initially it defueled just the same with trents modified torque-table tune. Then I reflashed it to a stock LBZ-airbox calibration with the Tech 2, then re-full-flashed my tune back in and thats when it started acting not as goofy anymore.
Another odd thing is trent's base torque tables and tliq tables were similar to some of my very old tunes (like from back in 06 when I had a stock LLY motor and BD turbo and raced it all the time) yet they only defueled sometimes...
So from what I can see, somewhere along the line maybe something outside of efilive's capability got screwed up in the ECM. :confused:
If I do an extended WOT run, it still throws MAF codes (and subsequently does odd fueling things) with the new MAF calibration that Trent helped me out with, so I still have some messing around to do with that. Even with the "out of range" enablers set way high it still throws P0101 and P0103.
You cant set those codes to "not report no mil" on an LLY (from what I have found) because that causes other weird issues and 'phantom' codes. For example if you set P0101 and P0103 to not report, you will be driving along, doing some WOT runs and all of a sudden you notice the truck just doesnt feel "right"...not as punchy as it normally is. Check for current or pending DTC's and there are none. But if you tell it to "clear codes" anyways, you suddenly regain the "normal" feeling in the truck. I had this happen a lot back in 06 when I first started racing my truck, so before each run I would clear all codes with the Tech 2 (didnt always work with efilive, sometimes it would still stay in the "phantom code" mode) and didnt really have as many problems.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
12
Wyoming
basically, the tech 2 reflash seemed to have a huge effect on this issue; an efilive full-flash didnt do anything.
