I think some have a miss conception of piston clearance in a running motor. Yes the aftermarket pistons run more clearance but that is because they grow more when they get to operating temp. Its not that they run loose in the motor(only when cold) they just expand at a different rate. Bearing clearance needs to be bigger if the power output goes higher. Things start to move more "flex" when you wick them up so a little extra is very much a good thing. I hope this helps some better understand whats going on in a race motor. I think a motor that doubles or more the output of factory rating is a race motor. Jeff
