MLG vs MLG-K
Roc8man
101
Mike,
What's the difference between these two converters? I know you mentioned it to me when I stopped by last week but I think you said the stall was higher on the K. What are the stalls for each?
Thanks
David
Roc8man
101
Have you guys tried towing with it? I tow 3-5 times a year with a 10k tow hauler...
Thanks for any help or advice.
David
Vsouth
137
Towing can be done with the K version. It takes a few rpm to get the load moving, but is doable. I had close to 30k miles on mine towing 8-11k.
It is not a towing converter, but it will work.
Mike L.
15,681
236
Fullerton CA
The G converter is a tight converter and stall would probably be around 1800/1900. It is not for big singles or high altitudes.
The K is around 2500/2800 stall. It's an amazing converter considering how it couples so hard after launch.
Verlon has had a lot of experience with racing the K and towing with it. Dustin has had a lot of experience racing the K also. There are only 5 out there right now but there will be a lot more pretty soon.:D
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
37
Goodyear, AZ
i got a question, what do you consider high altitude? anything above sea level? :joker: im at around 3-4k feet
and from what ive read the K converter would be great for twin/triple setup much more over a single? as you stated.
Dustin, is that with your new twin setup on the white truck or is that not finished yet?
hondarider552
Getting faster
May 28, 2008
10,627
35
Arizona
I have "stalled mine to 2600 but over 2300 it breaks all tires loose, don't need to push the converter that hard when I don't need to.
stall is only half the story. The part throttle coupling unlike any other converter ive ran.
05chevy
1,086
What is the price on the K. Looking to upgrade my converter with the engine build this winter
sickdiesel
Apr 22, 2010
1,019
I've been racing on the k all season with my old set up that was including the 10 sec passes.
The new set up with finished yesterday and I'm going to pick it up this weekend so I'm very excited to see how it acts with the new gt5541/gtx4202 set up.
sickdiesel
Apr 22, 2010
1,019
I think my stall is around 2700 or so. If I'm only on my 11.90 tune (around 1150-1200uS) it doesn't want to go over that unless I bump the brakes and flash it over it. On a bigger tune (1500-1600) I can get over that no problem as I typically launch around 3200rpms
Mike and georend have done a fantastic job on this converter and I think it's going to be the best seller once he launches it for sale!
Vsouth
137
The K converter is awesome for spooling at the line. I didn't realize how easy it was until I ended up with a much tighter converter due to my own desire for perfection. It can't be beat for a drag racing converter.
I put 200 passes on mine all at 850hp plus in a 7800lbs truck. It does what mike says it do. :D
Roc8man
101
Verlon,
What stall did you get since you got a tighter converter?
