So what are two stock lb7 cp3s capable of with lb7 regs? Power and rail psi wise?
Depends upon tuning. But the lb7 factory tuning is 160mpa. Duel fuelers Shouldnt exactly bump pressure just increase volume at higher pressures
It can be raised, but over 180mpa the ecm can no longer control the pressure because the rail pressure sensor can't read over 180mpa.
26106.8 PSIwhat does 180mpa add up to in psi?
