Should look into what im doing. 4 linked read bag behind axle, with
Plated upper fronts on air
Too.
Too.
Rclb ftw! Details on the suspension?
Duramaxbbd03...If you don't mind, what are your wheel/tire specs
Sweet trucks! any side shots of your red truck duramaxbbd03?
you guys that are super low is there any need to worry about cv axles pulling apart and if so couldn't you just use a spacer like on lift kits so the axle stays closer to the wheel bearing? hope that makes sense![]()
Oooooo...ahhhhhh. so pretty. So the red truck is on 3" drop shackles and front end decranked a bit? And its got the 305/50r20?
Sent from my DROID RAZR using Tapatalk
What you said makes sense. I have heard of a few guys that had to do something like that but those I saw were practically dragging. Maybe the 6/8 drop guys might have some issues like that.
