Lmm fuel filter life drops to zero
lb7duramax1993
Jan 24, 2013
21
Mooers,ny
I have a lmm with danville tuning which the big tune is 530 horse I just installed a air dog 150 and still every now and then the fuel filter life will drop to zero. Then it says change fuel filter but I don't get a low rail pressure code. Still has the stock fprv which I have a race plug coming. I don't have a rail pressure gauge to monitor just boost and egts. Could it be the stock relief valve letting pressure off?
Big Chris
That was a good dog
Mar 30, 2010
361
Rives Junction MI
Mine has done the same thing and I have a shimmed FPRV and I'm not running near as much fuel as you are. Possibly a fuel pressure regulator issue? Are your injector(s) failing and returning too much fuel?
02greysixer
1,829
7
North Central FL
Is your truck an 08 by chance? We have had two 08s in the shop doing the same thing. One deleted h&s tuned and the other bone stock. We didn't spend a whole lot of time on them but fuel supply vacuum and rail pressures were in spec. Couldn't really get anywhere with it.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
45
ZEPHYRHILLS, FL
Is the stock filter head still on it? If so do you happen to have a WIX plastic filter on it? Just helped somebody on Sunday with an 08 LMM with fuel filter life dropping to 0 on 700 miles or any time he got on it, and throwing the P0087 code. He had put 2 WIX filters on it, and they both did the same thing. Ended up being the WIX filter didn't have the tab in the center of it to depress the check ball and allow fuel to flow through easily. Put an AC DELCO filter on it and he was all good.
