To convert over to LBZ, You'd need the body side harness (complete with all connectors: ECM, TCM, TC, EBCM, Transmission, etc). In theory, if GM did it right, that harness should plug right in place of the LLY one since with the exception of about three wires (CAN and Driver request) and a few connectors, the majority of the trucks main harness should be identical. For the transmission, you'd either need to swap out the entire transmission or the Valvebody (including the IMS and internal harness, which is part of why you'd need the entire body side harness; the Transmision main connector is wired different, and the internal harness is also wired different and has several different connectors for the solenoids).
Pat, why do you say you wouldn't need the GPCM? The LBZ GPCM is different from previous years.
