Got the compressor side all done today. Just need a few parts to show up and then its assembly time!!
Yellowchevy
Yellowchevy
Can't stop looking at this thread!
Right on clrussell. Lot of Russell's around.lol... On goes my patient hat.
Haha..
I've changed my mind about 27 time already but pretty sure we are going to stick with a super stocker.
What options are you getting? BatMoWheel, Fingers Vanes, high Flow Turbine Wheel.....
I'm looking forward to your review/feedback
Corey
Corey
10 blade turbine wheel requires machining and believe Corbin is cheap!!:thumb::roflmao::hug:.
I'm looking for a good back to back comparison so I don't want change a ton. Being I'm going to use Corbins pickup I'm making him a good deal!!:thumb:
Ideally I'd like to
1 - dyno/boost test bone stock as it sits
2 - dyno/boost test ported/polished w/stock comp wheel
3 - dyno/boost test ported/polished w/wetzel comp wheel
4 - dyno/boost test ported/polished w/wetzel comp wheel & HX40 downpipe
But we don't have that much time!!
Yellowchevy
Ideally I'd like to
Yellowchevy
Sure ya do. He had a jeep to drive remember lol10 blade turbine wheel requires machining and believe Corbin is cheap!!:thumb::hug:.
Ideally I'd like to
Yellowchevy
I'm looking forward to seeing your results. I really like my LBZ turbo. I still haven't put a lot of miles on it but I'm very happy with my decision. ( I had Russell port and polish, rebuild, 10 blade turbine wheel and 63 mm compressor wheel) My truck is a poor test case because I had a non functioning stock turbo (stuck veins) and I'm not running enough fuel to really push the turbo. Normal driving it has stock like boost and lag. EGTs seem a little lower but when you get out of the throttle they drop much faster than stock. Exhaust braking is similar to the stock LMM turbo was. Not quite as aggressive at lower rpm levels but it feels very strong at highway speeds. It sounds like a 6.0 power stroke whistle. Noticeable in the cab but not obnoxious at all. Again, I'm running it just about as quietly as possible because I have the stock intake and am running a 4" Silverline exhaust with muffler. Straight piped and a metal intake may make it quite a bit louder. Again, Russell does great work and is great to deal with.
