In the progress of rebuilding an engine for my truck and the crank gear had a couple chipped teeth i got it removed but isnthere a process to install a different one or what is the best way to install it
Thats why I said start at 200* but you are right it may need a lot more but it is best to use as low as will work.
Most of the ones I've done always required much more heat to remove then install. I think it is because trying to heat it also adds heat to the shaft too plus any galling or otherwise will make it worse.
I've had to do some where I put the shaft in the freezer and bearing, gear etc in the oven. Drops right on at between 200 to 300 degrees with a negative 10* shaft
