Lb7 anyway to reset ECM?
Extended-lbz
Oct 2, 2014
26
My truck started idling around 800rpm, tons of engine noise and the transmission started acting really weird and aggressive. After some research I found that bad thermostats would cause this and I noticed my ECT was really low and my temp gauge was all sporadic. So changed the thermostats now it comes up to temp but I cannot get the pilot injection to come back on and it still is idling high and the trans is still being stubborn. I am getting a ghost code and my cheap autozone scanner will not pull the code, even when the CEL is on. I tryed autozone and their scanner will not pull the code either. Is there anyway for me to reset the ECM? Local GM garage wants like $120 just to hookup to it and they are booked 2 weeks out. I have tryed disconnecting the neg terminals and let the truck sit for 2 hours, no change the CEL still comes and goes but scanner will not pull the code.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
45
ZEPHYRHILLS, FL
Check your coolant temp sensor. If it goes bad, the ecm will think the engine is at the wrong temp, and do everything you describe. I normally replace the coolant temp sensor with an ac delco whenever one is in question because they're cheap(about $15 from amazon), and can be so sporadic it makes it difficult to catch one acting up sometimes. With so many systems using its input, it's mot worth chancing any problems with it.
Extended-lbz
Oct 2, 2014
26
For $15 I will give it a shot, this truck has been cursed
Extended-lbz
Oct 2, 2014
26
Can you send me a link to said sensor and im assuming the coolant temp sensor on the water pipe off the tstat housing correct?
Extended-lbz
Oct 2, 2014
26
Thats the one. Just put one in for my neighbor about a month ago in his GM using that very one.
Awsome thanks, Mine will be in tomorrow so I will swap it out and see what it does. Im going to drop the truck off at All in truck performance when I head back to NY and have a 02 OS flashed in with a single tune so hoping that will clear up the other issues I have been having
Extended-lbz
Oct 2, 2014
26
Well installed new thermostats and a new ECT sensor and un hooked the batteries for about an hour.. still high idle and the trans is still being wacky
Extended-lbz
Oct 2, 2014
26
Need to get a tech 2 on that thing, check ALL the sensors, could be a junk ecm or bad wiring.
Sounds like a bad ambient air temp sensor, but mine never made the truck idle high.
Its getting dropped off at all in truck performance here in TX in 3 days hopefully its a simple fix Im out of element and no resources as I live in NY. They are going to flash in a 02 OS system and hopefully can diagnose the truck
WVRigrat05
Wound for sound
Jan 1, 2011
3,124
26
French Creek, West Virginia
It's simple I'm sure, but without a good scanner you're pissing time and money away.
Everyone something went on my truck I was 3-8 hours from the house, swear they know you're out of town.
Extended-lbz
Oct 2, 2014
26
Haha yessir, I have access to efi live and a insight cts2 at home of course. Just didnt think id need it
nwodiesel
Mar 29, 2014
78
Thunder Bay, Ontario, Canada
I know this is an old post but this is exactly whats going on with my lb7. Did changing the sensor cure it cure it? Thanks in advance. Any help appreciated.Cory
