Kodiak thoughts for a step up from a 3500 d-max
wickedwhitetails
Aug 9, 2010
20
What are people's thoughts on the kodiak and top kicks as far as power, fuel economy, breaking, and overall ability to handle heavier loads. Currently we are using a 07 classic 3500 dually. Looking to upgrade to the bigger frame trucks. If you know of one for sale preferred to have lower miles and has to be 4x4 send me an email [email protected]
hondarider552
Getting faster
May 28, 2008
10,628
Arizona
They will handle the weight better than a dually for sure, mileage will be a bit less because of the gearing I believe they are 4.88 and 4.56? not sure on that.
Brakes are beefier as well. Compare it to a F450 and you got pretty much the same setup.
I know of an 2006 Kodiak that's for sale here in AZ with 7k miles on it if interested... I won't email you.
340
Axles, brakes, frame, wheels and tires better then 3500 lower gears help alot!
Everything else drivetrain wise is basically the same.. Get couple more qt for oil/transmission
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Empty the mpg would be less, towing I would think it would be as good or better. And the kodiak is a medium duty platform, no real comparison to a pickup as far as that goes.
clrussell
pro-procrastinator
Sep 23, 2013
5,918
385
I'll have Brassfield post here tomorrow.. They have had a couple of them.. They tow great but mileage sucks all the time..
Brassfield
Jan 14, 2014
185
West Plains, MO
2wd would be best for your mileage towing, I think they are 4:88 gears were our 4wd was 5:13. You will be gear bound with a 4wd, 70 while towing with our LLY we was about 2800 rpms if I remember right and 4wd with 19.5s barely got us out of wet grass. If your mainly highway i'ld lean towards a 2wd and better mileage while towing. Just my opinion after having one
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
I had a 2005 (LLY/5 speed), 2wd. Built trans and Duramax Tuner tunes. It got about 11 MPG with no trailer and mixed driving (and I wasn't easy on it). 8-11 MPG depending on how heavy and fast I was towing. It made a huge difference if I towed at 65 instead of 75+.
Brassfield
Jan 14, 2014
185
West Plains, MO
We had a local guy with 2wd LLY and 245/70s for tires that claimed 14 empty, 10-11 with horse trailer loaded. Our 4wd loaded was anywhere from 6-9mpg but could never keep up with our zf6 on the hills when we were both hauling hay
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
Mine was on 19.5s too. Guys say the OD increase going to 22.5s makes a decent different in MPG but I never got mine on before I sold it.
Brassfield
Jan 14, 2014
185
West Plains, MO
I think your shortest 22.5 will be around 38" diameter, your taller 19.5 tire diameter is 33.5". I believe they would help a lot, problem is the Kodiak's odd bolt pattern
DURAMXD
BOB SAGET!
Apr 24, 2012
348
Wichita, KS
Alcoas in the big pattern 8 lug on the Kodiaks aren't too hard to find. I bought a set on CL for $1000 with good steers and worn out drives. The 22.5s came on the motor homes, so that's where most of them come from that I found. You can get them in 24.5s too.
I sold mine with the 22.5s, here's a picture of it after the guys that bought it put them on.
Brassfield
Jan 14, 2014
185
West Plains, MO
Very Very sexual!!!!
