Is it time for injectors?
Samisunjp
33
North Carolina
I have been having a long crank issue (about 4ish seconds so nothing crazy) for a while. It has always started though. I added a lift pump and deleted the fuel filter housing and that made no difference. Changed all the soft fuel lines and that made no difference. Got two brand new batteries and that made no difference. Installed a new crank position sensor and that made no difference. Balance rates on the injectors are within spec although warmed up #1 and #8 are at about 3.0 which seems very high. I say that because supposedly these injectors were changed about 7000 miles ago at a shop prior to me purchasing the truck. The shop installed a new long block at the same time.
I did the injector return rate test by checking how much fuel comes out with 15 seconds of cranking at the return line near the fuel cooler and got just over 100 ml (about 110 ml).
Seems like it needs new injectors or anybody have any other ideas or things to try prior to going that route?
3,136
Do the return rate test on one bank at a time and see if you have one side making most of the return. You can then look more closely at that side and see if you only need to replace one or so injectors instead of all eight.
Another option is to send all eight out for testing and only purchase what you need. Your choice. Unless you have extra funds you need to get rid of, no need to replace good injectors. My 2¢
