LML How strong/reliable are lml delipped pistons
nc-12vpower
Mar 25, 2013
41
NC
I have heard that these hold up good for high horse power engines, but then I have heard that they have been having problems with them. Trying to see what the truth is behind them
juddski88
Freedom Diesel
Jul 1, 2008
4,655
119
Chesterfield, Mass.
I Dont think you're going to " find the truth" here. They've worked very well for some, and I could be wrong, but I'd be willing to bet their failure rate is similar to those that chose to run stock cast delipped piston in high HP builds. My opinion, if you want less than 1000hp and use it occasionally, they'd be a good low cost choice.
13,601
635
I would not use them simply due to the fact that they require you to modify the small end of the connecting rod. If you change the rod for the LML pistons, that's what you're stuck with, or you have to buy new pistons and rods if you decide to change.
nc-12vpower
Mar 25, 2013
41
NC
Thanks, didn't know that about the rods with lml pistons. I guess the best way to go is mahle cast motorsports pistons?
gmac32
288
3
bellville ohio
I am running delipped lml pistons in my setup. I figured someone has to try them out. I am shooting for a little over a 1000 hp when I am done. Up to this point everything is speculation on what they will hold. I will know how they do this spring.
nc-12vpower
Mar 25, 2013
41
NC
Okay well keep us up to date on how they hold up. How much horsepower have you made on them so far?
gmduramax
Shits broke
Jun 12, 2008
4,048
231
Nor cal
Did you break one?
No I haven't
I do not believe anyone has hurt Fingers pistons yet...
That's the thing "YET"
It gets annoying seeing people recommend something they haven't tested or haven't had long enough to know if they will hold up. Do I like the idea, yes. Will I run them, yes. Will I tell people they're the only piston you'll need to buy, **** no.
CaptPhil
1,012
Delaware
No I haven't
I dont think anyone has said that they are the only piston you need to buy. They are cut into Mahle Race Cast or Forged blanks though, so they start on a solid foundation.
they are probably the route that I will take when this engine gets built because I like the concept and their track record so far seems pretty good.
Has anyone broken a Mahle Race Cast with the regular round bowl design?
