after replacing my oil pressure sensor my oil pressure at idle is at 75psi cold.
initial thought was maybe there was too much oil so i checked the level and drained a little bit out, but it still continues to be 75psi at idle. i let it idle so the ect's can warm up to operating temps and the oil pressure is still 60psi at idle and goes up to 80psi when the rpms hit 1200.
the reason why i replaced my oil pressure sender was because it blew internally and leaked from the inside pushing the oil out past the weather proof o-ring on the electrical connector.
no leaks, oil level is a little low normal right now.
im out of ideas for right now
