Fleece transmission line
13,606
641
Yes. I had one that the fitting into the radiator kept leaking.
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
Go with drp next time or have a hydraulic ship make you lines. They just use parker hose and fittings. Much more reliable than what fleece sells. I with with hydraulics for a living the parker hoses are great
13,606
641
Go with drp next time or have a hydraulic ship make you lines. They just use proer hose and fittings. Much more reliable than what fleece sells. I with with hydraulics for a living the proer hoses are great
I prefer to use JIC spud fittings TIG welded to the factory steel line and push lock fittings and hose to make the rubber section. I've had it like that on my LBZ for 8 years and 140k miles with no leaks at all. It doesn't take that long to do either.
OregonDMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
That works I guess, seems like more work that it's worth. Hydraulic hose is just so damn easy and problem free and pretty much serviceable anywhere that sells hydraulic lines, plus they are cheap. Hydraulic hose is always better than the factory steel pos hardlines any day of the week but that's just my personal opinion.
1TRIKHD
Country boy Limo.
Sep 15, 2015
1,669
355
P.N.W
Ive had the drp lines on for 4 years no issues here.:thumb:
13,606
641
I prefer factory steel hard lines that are bent to follow the contours of the motor and frame and line up perfectly to all connections, and the push lock hose and fittings are available at any Parker store for very little money if you do have a problem (but with 8 years and 140k+ miles, mine are still leak free).
5,168
the steel hard lines are to beat with how tucked up and away they are from rubbing on things.
I went compression fittings on my hard lines to steel braided lines since my heat exchanger got moved to the driver side. 1 year and 10k miles on them with no leaks. just went over them 2 weeks ago too and nice and tight. Summit claims they were good to 300psi continuous when i called them as its their brand fittings and hose
AZlml
278
32
Goodyear, AZ
I got Summits hose and fittings for my c10. Price was right and it had good reviews. Still need to install it but it looks good sitting on the shelf..
