This is my first post and this looks like a great forum to be a part of.!
I'm looking for knowledge on swapping a Duramax into a 79 monte carlo (g body car). this car came equipped with a small block chevy, but will accept a big block chevy with a little modding. don't know if this info is helpfull when trying to find out if a duramax would fit into an application like this? I see a buick grand national on youtube with a duramax, which is the same body in general as mine, so I know it can be done, but with how much modding? I also hear that regular 700r4/turbo 400/turbo350 transmissions will bolt right up to the D-max?
what about fuel pressure? is a lift pump required to get fuel to the injection pump?
exhaust- does it come strait off of the back of the engine? (since the turbo is valley mounted?)
what about the electronics? can I run a stock ecm and just modify the harness to work with my car? or will it log so many faults for the electronic trans (wich won't be there) that it'll derate the engine? will a custom tune need to be involved?
what is out there for custom intercoolers on swaps like these? I know I won't have enough room for a stock d-max cooler, so somthing custom will have to be involved.
I'm an ex caterpillar mechanic, so I've got some diesel skills and fabbing skills, but need some insight as to the durmax in particular and swapping it out
Thanks a bunch!
Adam
Thanks a bunch!
Adam
