Duramax 2 step
RickDLance
1,276
14
Not the dance. Anyone make one yet??? I thought Ben or Fingers might be playing with one.
N2BRK
1,900
216
I thought there was one years ago that plugged into the OBD2 port
Tothemax
xgmtech
Oct 16, 2014
607
new york
bd staging limiter works good for me. lets me hold 30# boost with the diesel pedal to the floor while the brake pedal is applied
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Would be bad ass to find something that works. It's tough trying to watch tach and lights at the same time.
rfletes79
636
125
Galt, Ca 95632
My lb7 has a 2 step.... I use the pto feature in the tune, hook the ecm wire to my trans brake wire and adj according to track conditions. Works extremely well.
rfletes79
636
125
Galt, Ca 95632
Here’s a video of my car on the brake, bumping in and getting on the 2 step (pto). I only adjust the rpm setting up or down. Small increments go a long way. The rpm keeps boost in check and makes it very easy to stage/launch.
If you want more info I can email it over, logs, diagrams, videos.... whatever you need.
https://youtu.be/c2qILo1UJWQ
IdahoRob
Jun 5, 2007
1,151
What model engine/ecm will you be using Rick?
I used a DSP2 setup on Max'd Out (LBZ), the dsp2 could be hooked to a trans brake and should work fine with some trial and error.
13,597
627
That's basically what I did with mine except I used a relay wired to my trans brake switch and a DSP5 switch.
13,597
627
We have a customer with one, but it wouldn't work for him. The RPM just kept climbing regardless of how it was set.
Tothemax
xgmtech
Oct 16, 2014
607
new york
mine took some work to get it to play nice. if i remember correctly i hooked it up to my crank sensor. i know it tricky tho i have to push the throttle slowly and get it to my target boost then hold it to full throttle or it will over shoot. you can just smash the pedal down it will over shoot them back it self down to the target but then your usually past the staging beams
