as per discussion last night in the chat room here you go simon
the pipe my finger is on is the coolant recirc line
this is the turbo coolant supply line
this is you coolant for your cabin heater
this is turbo coolant return/discharge
looking at the water pump through the suction inlet pipe
looking at the w/p throuhg the re-circulation inlet hole
the other two is the discharger pipe from the water pump to the oil cooler and that connects to the intermediate/back plate
coolant path is form pump
to oil cooler
to back plate
to cylinder walls
to heads
to y-pipe
the cabin heater supply is tapped into upstream of the t-stats
the turbo coolant line is tapped in to the re-circulation line
that make sense simon? :baby:
the only thing that is regulated is the main upper radiator hose going to the radiator. there are hole ~1/8" in the steel of the t-stats nothing else is regulated
to oil cooler
to back plate
to cylinder walls
to heads
to y-pipe
