Crank no start white smoke when starting
Slippintrans
Aug 25, 2025
11
California
Help! 2001 LB7 will not start I was towing when suddenly heard a noise pitch change and then I let off completely and truck completely shut off on me. I tried to start it up and noticed white smoke coming out of the exhaust, truck is primed, injectors are being commanded and I'm seeing 1450psi at the rails when cranking was told to disconnect rail sensor to see if it would start still nothing, I have yet to see what injector balance rates are at, truck has diesel, good battery's, filters, fresh starter. frp is getting what its commanding where do I start?
gmduramax
Shits broke
Jun 12, 2008
4,186
326
Nor cal
Bad injectors ??‍♂️. You should be seeing 4000ish psi while cranking
White smoke is unburnt fuel. Injectors are probably leaking
3,123
Yep. Bad injector(s)
I had something similar with a stuck injector and lots of white smoke.
Pull all the glow plugs and crank it over to see which one(s) are dumping fuel
Slippintrans
Aug 25, 2025
11
California
So a return rate should 100 percent give me my answer right? and truck just hit 160,000 miles would my cp3 be a concern as im tackling the injectors?
3,123
Return won't reliability tell you which injector is hung or not
Slippintrans
Aug 25, 2025
11
California
Well I'm back new injectors and lines still crank no start trucks desired fuel rail pressure is calling for on crank is 6000 psi and it's cranking to 8400 psi still nothing truck has rpm signal I'm still pretty lost
3,123
Any smoke as before? Or at all?
EDU fuse?
Cam and crank sensors? Missed pulse count?
Slippintrans
Aug 25, 2025
11
California
Zero smoke im going to check the edu fuse , this scanner doesn't have the option to look at cam and crank sync but my rpms are jumping up on crank and ill check on the missed pulse count
Jakezed22
329
178
Maybe crank pin sheered and the reluctor is off?
Slippintrans
Aug 25, 2025
11
California
Ill remove the serpentine belt and check for play on the balancer but the motor sounds pretty even when cranking I did hit it with a bit of wd40 it did start for a second and sounded pretty normal it hasn't started since I'm gonna be borrowing a scanner later to see cam and crank sync and one thing I did notice the ficm hasnt had the plug in it since I got the truck wasn't aware prior to what that's what everyone talks about
Slippintrans
Aug 25, 2025
11
California
If it just slipped and went out of time/sync
What's the best way to figure that out
Slippintrans
Aug 25, 2025
11
California
looking for a reputable shop or individual to take this on in socal haven’t had a shop want to take it on or they’re too busy any recommendations ?
