Has anyone rebuilt thier own CP3 pump? I have seen a seals and bearing kit on Wicked Diesels website, is this a difficult project?
Alot of people think of the CP3 as a black magic kinda thing...and alot who don't would like everyone else to continue to think that way.
Whaat it boils down to is no one is really willing to divulge much info about these things cause they might lose their hold on that portion of the market.
JMHOP
If all you're wanting to do is rebuild the pump, and it isn't weak in the pressure department, then just snatch up the kit from wiked diesels...its not really that big or hard of a job once you have it on the bench. Now, if you are wanting to modify anything in the main body, be prepared as that is the hardest chunk of cast steel you'll ever hold in your hand.![]()
I think any modifications will require custom parts to be machined.
Just buy you a new one, they are only about $700 dollars and would have a warranty of some sort.
because buying parts and throwing them at a truck fixes everything?
In a nut shell, a weak pump will most likely always be a weak pump. It can't easily or affordibly be helped.
if your ponying up the $700 for all of us to own a new pump, Great sign me up. otherwise I think I will research the option to repair the one I got.
On another note: does a well worn pump fall into the category of a weak pump that will always be a weak pump?
Sorry for the rant.
