Hello all, I'm new to this forum. I was hoping someone could point out some potential problems for me. I just rebuilt my lml. Banks l5p oil cooler, new mahle cast pistons, callies alt fire cam, Wagner oil pump, lds reman injectors, lds cp3 and conversion, lds 64mm turbo, remote turbo feed, coolant bypass hose to heater core, etc. Started late Jan and just now getting back together due to breaking my leg.
Started up well, I checked the driver wheel well...looked good. Checked pass wheel well looked good then all of a sudden antifreeze is gushing out the lower rad hose quick fitting. I could be paranoid but the coolant seemed as if it had oil in it. Hard to tell with the clear break in oil. I probably blew a good quart of antifreeze out before getting shut down. I now decided to take the rad hose off to at the very least replace the oring and I only got about a gallon to come out. By the way to overflow cap was tight when it was running.
My wonder is am I dealing with an air bubble? Did I hook a hose up wrong? Is there something wrong with the coolant bypass hose? Could the banks oil cooler be an issue.
I now enough about diesels to be dangerous but yet I have been wrenching on stuff most of my life. Any pointer would be greatly appreciated.
