Question: Compression tester
battlegraduate09
Gearhead
Mar 18, 2010
610
Im not sure if its everywhere or just around my area, but they dont carry the one you need in store. I had to order online. I ran in in a hurry one time and grabbed the compression tester without looking really and got home to find that it was the wrong one. I went back to exchange it but they didnt stock it. Just an FYI
Item #93644 is what you want. I like it because of the 90* fitting, easier to get to the back cylinders in the truck
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I use the harbor freight one also. It's definitely a cheap tester. But seems to work well.
8,051
on the 06 and up, the adapter doesnt thread in well as the hex head gets in the way of the valve cover. you only get a couple turns in with it
1,457
Called luke day at day's diesel says he uses the said harbor frieght kit and the long adapter all the way up to 2011 trucks..
Guess we will see if i laundry $32.00 through harbor frieght or not
IdahoRob
Jun 5, 2007
1,151
I use the kent moore EN-47603 adapter for the 2006 and up with the harbor freight tester.
1,457
Some one got something wrong or changed something :mad:
Adapter fits nicely in the GP hole.. gauge doesnt connect to the adapter
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
37
Goodyear, AZ
Two different fittings. The right one is what i would expect from harbor freight with industrial style fitting the left one looks like wannabe automotive style air fitting mixed with a mine style fitting, or it was just missmachined. The mine fittings are automotive style just way bigger and longer
