8,045
Think im gunna give the limo another shot to tow the tracker out to KOH. Just towing either a flat bed or goose with a canam on it and tracker.
A/c compressor is leaking out the nose. Ordered another from napa but it was the wrong one. Decided to align it while i had it at work.
Explains the pull lol. Even though the caster is red, i prefer the higher caster numbers. After 45 min of tweaking
Drives like a dream down the road now. Correct compressor shows up tomorrow so ill get that swapped in then.
Also, it amazes me how much other shops would say this truck “cant be aligned properly”. No, it means your tech doesnt have an understanding about how camber/caster works and you just read what the computer says. They also struggle to center the steering wheel because these heavy ass trucks keep the floating front plates from actually moving during adjustments and the steering wheel turns instead even with the steering lock. If you just adjust one side at a time and make sure the opposite side stays at the same number it was before any adjustments were made, you can massage the tires/steering back to the center you made with some pushing. Hard to explain but simple to do once you see it.
3,058
Looks like your truck was driving sideways down the road. Any plans to try and adjust the thrust angle for the rear?
bluessmax
Tabasco Injected!
Nov 4, 2010
1,154
Lake Charles, la
You couldn't of said that better! Getting proper alignments is rare these days.
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
That’s a good alignment for California ?
8,045
China Lift blocks for ya. .25 of a degree isnt hardly noticeable driving. I think its like 1/8” of thrust when converted to inches.
It was funny how pissed the machine got when it saw the front end was 3” wider each side than the rear.
8,045
Wasnt a dig at your alignment guy, buddy. In his defense i adjusted ride height and redid UCA bushings so it was going to be off lol
Im just ranting how the alignment shops around is just suck. Only one place is decent and they are 2 hours away
all toe on one side and not even l/r?
Ones + toe and other is - toe because the steering going down the road wasnt centered. When i centered it on the rack, it shows how far off it was
darkness
1,537
584
vegas
Are there any Southern Tire Marts or other medium/heavy duty shops around? My dad takes his dually to STM because no one else in town will touch it.
gmduramax
Shits broke
Jun 12, 2008
4,185
326
Nor cal
Oh trust me I know the struggle. Only place I trust is an hour away. I tried someone new in town for The Limo and their alignment rack is off, not even sure how that’s possible. Found that out after I took my vette there.
8,045
Nope but doesnt really matter since we decided every one around us sucks so we got our own rack lol.
shakenfake
Moron
Sep 15, 2022
404
187
Shlumpt, TX
I also take mine to a heavy truck shop. No machines there.
I once got an alignment on a lowered 1500 that lasted all of 400 miles and they told me I was trying to pull one over their head and I changed out all the parts. Idiots.
SoCalMike
851
79
California
It's starting to get busy out here with people heading out to KOH. I live about 45mins from there. I just looked it up and didn't realize it started around the 18th. It must be people heading out for the weekend. Good luck out there James
Sent from my SM-S928U using Tapatalk
8,045
Thanks Mike!
The desert course has a 10-15 mile shitty rock section but otherwise its a blast. Tracker handled it awesome till we got into big ass whoops. Need to slow the rebound down on the back end and i think it would be better
clrussell
pro-procrastinator
Sep 23, 2013
6,034
527
Man I had never paid any attention to king of the hammers.
Wow it is an event. It would be pretty damn cool to spend a couple days there
8,045
Have not done a whole lot. Picked up a randy ellis light rack for the front bumper. Going to put some 7” or 9” lights up there. For a 130 bucks, i wasnt going to pass it up.
Buddy of mine hit me up friday noght to do a last min single track ride up in flag (1.5 hours away), erin took her truck to her dads so they could go to Cheyenne for the weekend to visit fam with the kids. I couldnt go due to work (flights left during work time). Limo had a tcase leak i needed to fix and wound up being the top plug for the snap ring on the back case half. Cleaned that up and siliconed the plug back in. Did notice the water pump is leaking oil so im guessing the o-ring failed. Have to fix that at some point. The new napa compressor i put in a while back, failed at the body so i replaced that a couple weeks ago.
I wanna get these leaks fixed and that alternator issue fixed, then start interior stuff
